It is currently Sun Aug 24, 2025 1:07 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Tue Apr 23, 2013 9:04 pm
Mahogany is one of the more stable woods which is why it was the perferred wood for pattern makers, not to mention guitar necks. Still is I suppose for the few pattern makers that are out there who use wood.
You should try to get your hands on Bruce Hoadley's(sp?) book "Understanding Wood". What you actually want is a wood that has it's tangential shrinkage and radial shrinkage as close together as possible. He has a list of a veriety of woods showing the shrinkage and shrikage ratios in his book. Perhaps your library has it.
A lot of very good information in his book on humidity and wood movement by the way.
PostPosted: Wed May 01, 2013 9:47 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Thanks, Jim. Sounds like a book that's well worth having. Will do.
PostPosted: Wed May 01, 2013 11:12 pm
First name: Ringo
bluescreek wrote:
I have worked with Catalpa and that is about as stable as a piece of wood can be. There are a few factors you overlooked , and that is how it was dried. I find kiln dried to be more stable than air dried . Also the cut . while well quartered may stay flatter it may shrink and expand more than flat sawn.
All wood will move to a degree.
Petrified is the most stable and you don't need a filler
No, it's quite the opposite; as a general rule wood moves about half as much radially (quartersawn or vertical grained) vs tangentially (flatsawn).
PostPosted: Wed May 01, 2013 11:19 pm
First name: Ringo
Indeed, a big part of why mahogany has been so popular throughout the ages is 1) it is quite stable, and 2) it is one of very few woods which moves almost the same amount in the radial and tangential directions, so it really doesn't matter whether it's quartersawn or flatsawn or anywhere in between.
PostPosted: Thu May 02, 2013 6:05 pm
Last Name: Hosmer
If you must use a domestic wood, southern magnolia would probably do well for your project (3D puzzle?).
The T/R ratio of southern magnolia is probably the best of our domestic woods, but exercise caution when doing the "ultimate T/R search". A wood can appear suitable from the standpoint of T/R, yet be substandard in regards to volumetric shrinkage. A case in point is yellowheart.
Always have plenty of sandpaper; it's rough out there!
Users browsing this forum: CarlD, DennisK and 13 guests
